Jsocect
Now that we are making some progress on our build, I figured its time to organize a thread for it.
2007 Mazdaspeed3 purchased from a fellow Nator member in North Carolina (Brandon)
Received the car on July 2, 2015
Already installed: BC Coilovers, Corksport Rear sway bar, Stainless Brake lines, BBS RK's
Car was in very good shape, inside and out. Bumper was replaced due to some cosmetic damages.
Once we received it we immediately took apart the block for inspection. We purchased the car knowing it had spun a bearing, it was perfect for us as we were planning on building right away.
Plan: We originally intended on building a track car. But considering how much time we spend at the shop working on customers engines/parts, we decided on a street car setup.
Manley H Plus Rods
Wiseco Pistons
OEM Bearings
Supertech Valve Springs and Retainers
ARP Main Stud kit
L19's
ACT 6-puck w/ Flywheel
Autotech HPFP internals
Cerakoted piston crowns
Cerakoted combustion chamber on the Head
Cerakoted Valve bottoms
Microslic Valve stems
Relentless PNP Head w/ polished Exhaust Runners
Head coated in Cerakote Heat Dissipating finish
Damond Motorsports Motor mounts (3)
16W Vband Exhaust Manifold
Precision 5858 Turbocharger
Cobb V3 AP
DISI injectors cleaned and tested, installed w/ Corksport seals
Treadstone TR10 coated in Cerakote Heat Dissipating finish
All powder coating, porting and polishing, ceramic coating and assembly done in house
Assembled by Javier and Digno (mostly Digno)
If you guys have any questions regarding pricing for anything powder, porting, ceramic related.. email is sales@relentlesscustoms.com
For questions regarding engine builds.. email is support@relentlesscustoms.com
Thanks!!
Manley H Plus Rods
Wiseco Pistons
OEM Bearings
ARP Main Stud kit
L19's
Cobb V3 AP
Thanks!!
