And spray meth. Long-term solution that'll keep them clean. And all sorts of added benefitsThis would give me an excellent reason to actually clean my valves like I've said i was going to for 6 months.
So on the one hand we have the Damond ST IM adapted kit, which costs $449 (with TB wiring harness extension and modified ST manifold options included), plus at least $250 or so for the under-routed hotpipe, custom-figuring out the coldpipe situation, has no PCV return (need EGR block-off) and VTCS disabling, and offers ~330 cfm/cylinder with ~2% variance between runners. So the out-the-door cost would probably be in the $750-$800 range with incidentals, etc. This actually brings the price in the same range as the JMF.Alright here's some data!
Average Runner Length: 8.75 in
Runner Cross-Sectional Area: 2.60 in^2
Flow per Runner @ 28" H20 below (Intake Manifold Only):
Note: the engine shop labeled the cylinders backwards
This manifold is designed to be a bolt-in. It’ll work with the stock throttle body, stock intercooler, stock you-name-it. This means if you’ve upgraded to a front mount intercooler, it’ll also work as it keeps the OEM throttle body location.
I don't see that verbiage on the page you linked. Am I just blind? (And I believe you, I just wanted to see the original content.)According to their page
http://www.corksport.com/blog/we-need-your-feedback-on-our-mazdaspeed-intake-manifold/I don't see that verbiage on the page you linked. Am I just blind? (And I believe you, I just wanted to see the original content.)
On the other hand, we have the CS. Although it flows ~275 cfm (as opposed to 330), it has <1% variance between cylinders and still flows a LOT more air than the ~200 or so of the stock IM. I'm curious, @Barett@CorkSport, will this retain the PCV return fitting and work with FMIC piping that descends between the IM and the radiator, or will under piping be needed also? What about with a thicker radiator, like the Koyo? How about needing TB extension harnesses for the wiring? Will it include a solution to address no VTCS CELs? Ports for supplemental PI or methanol nozzles? And finally (something I'm sure we all want to know), what price point range are we looking at?
Sweet! So, I'm guessing you made provision to plug in the stock vacuum line, etc., too (like near the intersection of runners 3/4 on the stock IM)?Hey Redline,
The CS IM does retain the PCV port (or you can get a plug for it instead of a rubber cap) as well as mounting locations for the TMIC. The only mandatory losses are the EGR and VTCS which is a common mod for even the stock IM, however we do not have a solution for the CEL's.
As stated by a few others, the CS IM is designed to be a OEM replacement therefore maintaining the TB, PCV, TMIC, and packaging constraints.
This may be surprising, but the CS IM actually provides more room between the radiator and the IM. This allowed us to located the runner meth ports on the front of the IM instead of the top so that the customer could still use a TMIC. dale_gribble should be able to confirm this, especially driving an MS6.
We do not provide provision for PI on the runners other than the 1/8-27 NPT meth ports.
I can't give you an exact price point right now, but I can say that it will be at or below the price stated in the blog...and the idea of a pre-buy is interesting...
EDIT: dale_gribble in MSF (not MSO) is a beta tester and has posted pictures.
Yup. Ports, hardware, and lines for the brake booster, EVAP, and BPV along with an extra port.Sweet! So, I'm guessing you made provision to plug in the stock vacuum line, etc., too (like near the intersection of runners 3/4 on the stock IM)?
nopeIs there a provision for mounting the vcts solenoid? The cel can be fixed by simply leaving the module plugged in, no need to actually do anything. If there was a provision for mounting it somwhere that the stock wiring would reach it would completely solve that problem.
are you saying it simply needs to be plugged in? bc the little valve can come off the black box, or does it still need the vac lines hooked up?Is there a provision for mounting the vcts solenoid? The cel can be fixed by simply leaving the module plugged in, no need to actually do anything. If there was a provision for mounting it somwhere that the stock wiring would reach it would completely solve that problem.
Looks like you need to put in some overtime this weekend then.nope
Let me get out my chisel to modify the mold real quick...Looks like you need to put in some overtime this weekend then.
LOL... I do think the vtcs box could be mocked up thoLet me get out my chisel to modify the mold real quick...
GEEZ GUYS! I'm trying to get you all the POOOWWWAAA and you're wanting provisions for VTCS...LOL... I do think the vtcs box could be mocked up tho
We appreciate it! It's just that some of us can only have so many "not readys" for emissions, so being able to have the actuator bolted up/plugged in is helpful, even if it's not doing anything.GEEZ GUYS! I'm trying to get you all the POOOWWWAAA and you're wanting provisions for VTCS...![]()
