jsilva
I was trying today to separate the block from the transmission but was having issues.
All of the bolts are removed and I was able to get it about 1/2”-3/4” separated all around. However, it wouldn’t go anymore than that.
I should say that I’m actually trying to pull the block away from the transmission (the engine was completely disassembled and is just the block and is disconnected from everything and has about 4” of space on the opposite side). The transmission is still connected to the mounts, transfer case, etc. The reason why is that I am needing to get to the crankshaft ASAP. I’ll worry about the transmission later.
Is there something else that needs to be done to get the transmission separated? Or do I just need to keep trying and get the right angle?
