KingScumbag
Sorry for dumb question, I'm still trying to learn about PI and such. That looks nifty tho.This fuel distribuition block, off the feed at the firewall. Will split. 1 line to the HPFP. The other to the PI rail.
View attachment 9582 View attachment 9583
What shielding did you use and is that red rtv to hold it? Mine is hot garbage and needs replaced might be good to do when the engine is all out.
Kmac is an OG member from MSF. Hes not around anymore.Kmac? Is that an old member/vendor? Not familiar with the manifold.
I take it that you are running no return on the PI side?
That manifold looks like he cut an OEM flange off the stocker and welded a sheet metal block to it. Nifty. I remember Kmac, he had really interesting stuff made.
Ask away, I have no quams with anything. Whether its negative, positive or requests for knowledge lol.
There's quite a few EFI regulators that are block style regulators It utilizes the bottom port and and has two outlet ports with one plugged. As opposed to a bypass regulator with a return.Coming together nicely man.
Just curious how you plan to run the Fuel Reg without it returning to the tank?
A few people are running the 2011 2012 2013 2014 CHRYSLER 200 3.6L THROTTLE BODY 05184349AC. It's 75mm and you can swap some wire as far as I know. Finding the harness sucks butt so I would just check junk yards or ebay.
https://www.ebay.com/itm/2011-2012-...epid=1130281351&hash=item56a258b842:rk:1:pf:0
