JohnnyTightlips
Motorhead
Here ya go. OEM - TB Measurements
Yea that didnt match either. At a loss now for what he could have used lol.
I'm also in the middle of a dilemma in figuring out if I want to run a return to the tank with a bypass style regulator. I just dont like the idea of the warm fuel going back into the tank. For a few reasons. Itfp health and obvious fueling reasons. I'm still about 80% on the dead head setup with a blocking style regulator. The itfp regulator should do fine at minimizing any lock or spikes in the system.
So I'm toying around with the idea doing it with an inline cooler mounted on the frame rail about midway between the regulator and the tank.
Winter is too long to be planning and thinking of things like these lol
Adding a return is a s simple as running a hose off of the rail to wherever you want with a regulator.
But since you are already set on running a regulator, I suggest just going for a return style while you're there.
Sent from my Pixel 3 XL using Tapatalk
With a return style how much heat is really being put back into the tank?
Hey dad, when you did the AEM pump did it just drop in with no modification? Plug right in? And wiring differences? Looking at that same AEM and wanna make sure it all workies okay.
