Shedbuilt and Scumbuilt
Why didn't you just go with a CS throttle body? it's a 72mm PnP. I think the most you would have to di is possible make an adapter plate for it depending on your bolt pattern.
I'd have to make an adapter plate anyways. I'm not spending 350$ on a TB. This TB was 60$ on rockauto and is 70mm.
PnP doesnt really bother me either as I'll make everything PnP myself.
That is a great reason. Carry on.
I paid 20$ shipped for mine and it came with the harness so......... ;) I will let you know if I get an adapter fabbed that works well. @Maisonvi would be doing the hard work for me.
I may be looking into just grabbing this TB myself as it matches the inlet size of the IM.
A bit of update
- ITFP pulled. (Btw an old bad PRV makes a perfect plug for that feed line lol)
Installed the AEM 340 pump. fit perfect as I thought it would. Want to utilize the retention cap so will be ordering a OEM filter assembly. The old filter was BLACK!
-Turbo yanked to send out for a refresh.
- started to mock up fuel lines to run. Didnt have my AN wrench (at work) so haven't starting assembling anything yet. Shouldn't take but an hour to even get the fuel lines mocked up, made and ran to where they need to be.
Also to add to the list, I want to clean up the custom coolant feed and return for the choo choo.
20181203_122927.jpg 20181203_123309.jpg 20181203_100545.jpg 20181203_105514.jpg 20181203_124947.jpg 20181203_110720.jpg 20181203_131040.jpg 20181203_112151.jpg 20181203_112218.jpg 20181203_122921.jpg
For the Chrysler tb, once you make the adapter for the plug, I believe all you need to do is swap the middle two wires on the harness. @CMajor should be able to tell ya for sure. He has it on his car.
Also, Heads up, you'll want to switch to VT from Cobb if you don't want the ridiculous on/off throttle jerking from fuel cutting well before the throttle plate closing on decel.
Unless Cobb has released these tables. (roads like tail of the Dragon would be horrendous with the Cobb tables)
And here's the adapter we used for jmf and 16w fab Manis that both had 75mm tb intlets for the TB
received_10103591439533572.jpeg received_10103591440267102.jpeg received_266989757343590.png received_266118214053715.jpeg
[doublepost=1543890598][/doublepost]You also have to make the bolt holes on the TB a bit oblong for every thing to lime up. Unless kmac made the flange specific for this TB (he may have?)
@Sho interesting. Thanks for the info.
I'm assuming it's the increase In air volume that requires you to have those tables to be adjusted?
I'm going to look into the cx9 TB kmac was using at one point as well.
Yea, this IM venture is turning out to be more than I wanted it to be. Not even the Chrysler TB matches this IM.
I'll probably just send it on the OE ported IM and see where that leaves me at this point.
I could chop the flange off and weld a new TB flange onto it. But then in already in further than I want to be on principle lol
Sad to see you giving up on that intake mani. What was the mani originally flanged for?
I think the community has been asking Cobb for those throttle tables since 2013 when Pablo and Skater-boy tried that Chrysler throttle body. Dont hold your breath on them ever doing anything about it.
@KingScumbag what oil drain did you make for the BNR? I'm finishing up my S4 install and not loving how the OEM drain had to fit, might have to explore other options later.
