Hey sho I will be building my motor in the spring. How DD friendly are the 2618’s in your opinion. A lot of times I start my car and drive off (not getting into boost of course)and it is my main concern with piston choice.
Yeah, however, your maintenance ethic along with your acuity to realize, and act on things that are not correct rather than continuing to just keep ripping on it also plays a major roll as well. Contrary to popular belief, a “built motor “ while more tolerant to detonation, it is not immune to lack of maintenance, its just built to handle more power in the same normal order of things, imo anyway.
See you at 100k
I guess it’s the pwc you have to have that causes that right? Do you burn through much oil?They're very DD friendly in that they obviously last a lot longer than people expected them to.
On my car, What they do not like is being driven or put under any sort of load unless coolant temp is over 140* (car bucks wildly and has barely any vacuum until that point ) . I always let the car warm up to that once I found that out. The car is essentially undriveable til that point. I'm also a big believer that my motor has lasted as long as it has, because I don't just hop in it and go.
Half a quart every 3k miles at 80k+.I guess it’s the pwc you have to have that causes that right? Do you burn through much oil?
Wow yeah that is pretty good man. Dang I hope I have as good of luck with my built motor as you! Any crutial points of the build to pay extra attention to in your opinion. I’m palnning to do a full rebuild/build. VVT, oil pump, etc.Half a quart every 3k miles at 80k+.
Nothing substantial
Sounds similar to what I am wanting to do just using mahle pistons. Basically a copy of Corksports stage 1 built longblock without cams.My motor is such a simple setup. When it was assembled in late 2015 this is what it had done:
88mm Manley Platinum series pistons
Manley h beam rods
OEM rod and main bearings
OEM main studs and head bolts
No head workb(porting etc)
Stock valve train
At 55.5k miles
The balance shaft was deleted
Rear main seal was replaced due to a leak
At 73k the head lifted from running 550whp/440tq on stock head bolts.
Upgraded to L19 head studs at that point and replaced the head gasket.
Other than that, I only use quality oil and change it every 3-3.2k miles
I've never run straight 93 octane in it either.
From break in to 7k miles, I ran E23 mix on a pte 5858 at 22-23psi.
From 7k to 50k, ran E23 + 2000cc/min meth on a pte 5862 at 35 psi and 500whp/391 tq
From 50k to 70k ran E48/E50 on 6th port at 540whp/405tq
From 70k to present E48/E50 w/ port injection at 575whp/467tq
Car sees proper warmup each time it's driven and always brought up to full temp before shut down
Something wrong with the 5862 or just going for more power?Rolled 82k last night.
Also ordered a 6266 to replace this whooped 5862, back on the 20th. But apparently PTE is taking their sweet time with shipping orders right now. I hear from folks it'll take 3.5 weeks minimum to show up....
It also has 82k miles on it, has been smoking for the past 26k miles, is leaking past the seals and I want more power down the road. Gonna run the 6266 at 600whp til this current motor hits 100k Then toss in a sleeved motor built to the moon and go for 700+Something wrong with the 5862 or just going for more power?
Are you familiar with borg warner sizing? Is a 363sxe close to a 3076?It also has 82k miles on it, has been smoking for the past 26k miles, is leaking past the seals and I want more power down the road. Gonna run the 6266 at 600whp til this current motor hits 100k Then toss in a sleeved motor built to the moon and go for 700+
A s257sxe is close to a 3076, the s363 is a much larger turboAre you familiar with borg warner sizing? Is a 363sxe close to a 3076?
That is a monster turbo.Are you familiar with borg warner sizing? Is a 363sxe close to a 3076?
Ok thanks man! I was considering buying a 257 sxe instead of a gtx3076A s257sxe is close to a 3076, the s363 is a much larger turbo
