Sho
Well, with built motor #1 being over 83k miles and somehow still kicking, I figured now is the time to get the ball rolling on a second motor.
Purchased/acquired so far:
- 87.5mm wiseco one-off pistons w/ 12.5:1 compression ratio, gas ports, exhaust valve reliefs, etc (thanks Mark / @Realgib3 for the smokin deal on these!) these had roughly 2k miles of use on them.
-ARP Main Stud Kit Mazdaspeed 3
-Mazda OEM Water Pump Mazdaspeed 3 2007-2013
-Massive Speed Balance Shaft Delete
-Massive Speed Oil Pan Baffle Mazdaspeed 3
-Manley Platinum Series Piston RING SET ONLY (have to see if these will work with the wiseco pistons as I will not use wiseco rings due to oil control ring issues... If not, I'll hit total seal with specs and get some from them)
-Manley H-Beam H-Tuff Plus Rods w/ ARP 625+ Rod Bolts Mazdaspeed 3
- Number:42548-4 Heavy duty wrist pins
-Mahle Clevite Rod Bearings H-Series Performance STD Size set of 4
-Clevite Main Bearing Set STD size
My darton sleeve order from amazon got canceled, so trying to find another distributor that has em in Stock. Will order again by end of week.
Updates for now will be just of stuff I order. But once I get the sleeves, will be dropping a motor, the sleeves and the pistons off for machine work!
