squingy
I have a few questions:
Have you had any issues with your ABS setup?
Did you cut the stock rear ABS sensor harness to install the CX-7's?
I looked at the wheel bearing that you used for the front passenger side and the description doesn't say if it has an abs magnetic strip or not, so does it work?
Thanks.
Thanks.
