Speedie6
Silver Member
My MS6 has been sitting in my garage since 2013 or so. I f'ed it up. I had trouble deciding to drop yet more cash into it. It was my first, and really only performance car and I didn't know what I was doing. And wound up dropping way more money into than I should have.
But, I finally decided that I should poop or get off the pot and decided to go ahead and build it. I probably shouldn't even be posting here because it really isn't my build, not my work. Being done by a shop in Houston. Kozmic Motorsports. Well, I did a little here and there myself. I put in a custom FMIC and hacked my crash bar, stuff like that. But the heavy work of putting in the engine, fuel system, clutch is being done by the shop.
I ordered the engine from Speed Perf6manc3 and waiting for delivery, hopefully in a week or so. The plan is for about 600 whp. Here is the project build list as it stands:
Speed Perf6manc3 built motor, stage II+ with Kelford 247C cams, JMF intake manifold with port injection, port-inject fuel kit, XClutch twin disk organic clutch, brass shift fork pads, Precision Turbo PT6062 (w/Ceramic), Tial wastegate & BPV -- CPE cast exhaust manifold w/ceramic, rearward rear diff mount, Guagepod, TowPlate -- Damond Motor Mount Set, PVC plate, power steering cooler -- Corksport throttle body, stage II big brake kit, skid plate, 4” intake -- TurbineTech forward rear differential mount -- Cobb AccessPort -- RPM Sport springs, Bilstein Shocks, SPC ball joints, AWR end links (F&R) -- TWM Stage-1 Short shifter with bushings -- Street Unit radiator hose set, Whiteline swaybars -- custom exhaust, custom FMIC, custom downpipe
