StreetSpeed’s DD 500+ MS6 Build
Which should I get for Christmas?
  • Big Fmic Core (tr9/10 or equivalent size)
    Votes: 1 20.0%
  • EWG conversation for my CST4 setup
    Votes: 2 40.0%
  • Rear Diff Mount
    Votes: 2 40.0%
  • Total voters
    5
  • Poll closed .
How do you adjust clutch uptake?
So lay in the floor board (uncomfortable ik) and look up the clutch arm a good bit and there is a rod with a nut on it that goes through the clutch arm. The LESS threads you show out the front of the arm towards the driver's seat the HIGHER the engagement. The MORE threads showing will lower the engagement. :)
How did I never know this... thank you!
I always liked where my clutch engaged but when I installed this new clutch it would've been a nightmare without having this adjustment! Glad this info is helpful :)
I upgraded my entire clutch line and slave to a supra type slave and it has made driving it a dream. Feels closer to a stock clutch when pushing on the pedal. Just an fyi for ms6 owners.
I purchased a ss clutch line from Edge but I didn't realize it only replaced the very short section of rubber hose. I thought it was going to get rid of the funky swirled circles that go to the slave. I decided not to even mess with it yet but I am not picky about clutch stuff too much and it is doing better now. I think the clutch is slightly breaking in and I am getting used to it.
My pressure plate must've been absolutely shot. This clutch is supposed to be close to stock feeling and it almost doubled the pressure it takes to use it now lol Still glad and worth it so oh well
I also removed my spring and installed a linear spring to help pull the pedal back. I also have the ramfab firewall brace which is needed to help with the firewall and clutch pedal cracking.
So I had a blonde moment apparently and didn't hook up my vac line to the EWG so that explains it not controlling my boost. As for my boost now....... It got neutered lol I am subject to only 10-12 psi now and it is stupid slow lol
It sadly feels fast since I have driven a beater pickup for 9 months or whatever but VD says it was very uneventful lol Needless to say I got a first wot pull which is progress nonetheless!!
Should be doing a stock fuel tune on it this week and fuel seems to be going further this time around which I suspect is from cleaning my filthy hpfp that had some slight 'black death' inside it.
Wastegate is WAYY LOUD lol It literally cracks at like 7psi right now and hits 11-12 so basically loud at 30-40% throttle lol PI will be next with my new SSC and Wotbox install coming soon! Got the correct injector plugs wired up and ready to go! :)
  • 3rd_gear_wot_ewg_only.csv
Got my new rear bumper exhaust shrouds on and it looks so much better!!!! I opted for the led lights in them too which wired up pretty easily and I the new look so much!!! It was worth it even if it was $350 or whatever lol
Perhaps black with a white mark on mine. Been a while since I ventured under the dash. What spring did you replace it with?
Here are the pictures of my spring setup.
I know I haven't posted in a while but adulting lol Anyway, I got some time yesterday evening to wire up the Split Second Controller. I opted to strip back the wires and solder the SSC wires onto everything. Guess I just get nervous cutting important wires lol Hooking up the fuel lines hopefully in the next few days and will be able to check if it is working.
Once it is working I will install the wotbox as well. Decided even though bambi busted up my front passenger corner, I wouldn't let it stop me from continuing my stuff until it is fixed :-)
Once it is working I will install the wotbox as well. Decided even though bambi busted up my front passenger corner, I wouldn't let it stop me from continuing my stuff until it is fixed :)
Lmk if that fuse location works out because i have a gaurdian angel and an aux fan controller i still need to hook up and im worried i will run out of room in my fuse box.
Should be getting a few -6an to -6an fittings I need to hook up my fuel and check for leaks. I reused my factory line with quick connects by cutting it in half to make the two separate lines I needed.
Took a few pics and also a couple of how I decided to route the fuel line from the firewall to the passenger side of my pi rail.
Originally I was only going to tee into the line coming off the firewall and one line was going to the hpfp and one to the pi rail. Doing this though would make my fuel run into a dead end at the far side of the pi rail so done what Will from PD recommends.
Ran feed line from firewall to far side of pi rail, then out the other side of pi right up to the hpfp. Should flow without a full dead end this way and will probably run a return line in the future for better fueling capabilities.
So I ended up using a different fuse. I unplugged the fuse and hooked up my multimeter with the key off and it was reading voltage so I didn't use it. Got my fuel lines ran and leak tested and all is well.
Need to get a cable to connect my laptop to the Split Second Controller and test the injectors now. Fixing a giant exhaust leak around the turbo area as well that has gotten worse over time. Pretty sure I warped a vband or even both while welding them up. Rookie mistake for a first time tig welder.
If anyone knows about the possibility of regular mazda 6 aftermarket headlights working on a speed 6 let me know!
Here is a picture of my speed 6 plug and the plug of the aftermarket regular 6 headlights.
Thread viewers
