RISE FROM YOUR GRAVE!
HOKAY so quite a bit of my prior math was wrong; I wasn't thinking about shit properly and it didn't dawn on me until last night when I tried to figure out load vs AFR vs injection amount. I wound up throwing my notebook (covered in math) down on the table in disgust after realizing that the numbers I was looking for was one of the ones I was starting out with (more on that in a bit), and that spilled over into the realization that I was doing my flow calculations for the HPFP and injectors incorrectly.
Let's take a look, shall we?
We will skip the top section for now as I covered all of that (except BSFC, which doesn't need to be explained here really) in a prior post; starting at the first line after the black bar:
RPM:
This is engine RPM. Duh.
HPFP Flow CC:
This is how much fuel the high pressure fuel pump is capable of moving at a given RPM.
Est. Flow WHP / WTQ:
This is the mathed out (inaccurate, not real world) estimate of how much power and torque to the wheels the HPFP is capable of feeding.
Injector Overrun CC:
This is where things get interesting. A negative number here is how much more the injectors can flow than the HPFP (in CC/Min) and a positive number is how much more the HPFP can flow than the injectors (in CC/Min). With Autotechs (referenced in parent image), we run out of injector pretty quick.
Offset WHP:
This is how much WHP is lost by not having a large enough HPFP (negative number) or by upgrading to larger injectors (positive number; these don't really exist BTW) that matches either the injector or HPFP flow rate.
HPFP + Inj. WHP / WTQ:
This is the mathed out (inaccurate, not real world) estimate of how much power and torque to the wheels the HPFP and injectors are capable of feeding, limited by the lower flowing of the two per RPM. This is why torque drops off right as horsepower plateus; you go from the HPFP being the limiting factor to the injectors being the limiting factor. Simple.
So, why does this matter to anyone? Well, let's take a look at some stock HPFP data:
Looks like it's possible to max out the injectors with the stock HPFP. All you'd need is a bigger turbo and a tune to do it (probably shouldn't try this, unless you're actually interested in the result in which case, PM me for science).
What about if we fill the tank with corn?
Ouch. Limited to 221 WTQ (ish, this doesn't factor timing only fuel) and 252 WHP @ 6k (which should look familliar to most stock turbo owners).
What about corn and Autotechs you ask?
Looks a lot like a stock turbo tune, doesn't it?
"Well, that's all well and good, but why should I give a shit about this, you fucking spreadsheet nerd?"
This stuff, I don't expect anyone to care about. What I do next, however, will probably turn a head or two.
How would those of you that tune, self or otherwise, like to input a torque/power curve and get back a per-AFR and RPM target table that has all the calculated load values in it?
Not blowin your skirt up much? Ok, well what about automatically calculating the MAF curve for aux fuel and stock injector cutoffs and shit like that for a given power target, with the injector, nozzle, and duty cycles laid out for you for 5th/6th port, pi and meth?
Still not enough? Have another idea that fits in with this theme? Make a request; I'm not going anywhere.
In the mean time I'm going to bounce this output table I have set up (that already matches a log file or two) against some more pro tuners (thumbs up already acquired from VegaTuned and PDTuning) before I move forward on the other goodies.
