Worbit
Platinum Member
So my car is throwing a code of P0302, misfire on cylinder 2 and has a rough idle under low RPMs. Smoke is coming from both exhaust tips and when the plugs were pulled, plug #2 was caked in oil. replaced the plugs, still having the code/rough idle.
After doing some searching it seems like it can be a number of things: Ringlands have shit the bed, injector seals are failing, possible head gasket issue, etc. Has anyone else had this exact issue before? I only seem to find bits and pieces of this on MSF and I refuse to trust the solutions posted on 24/7 or any of the other sites out there.
Car is going to sit for a day while I locate a compression test kit or build one at Home Depot if I get desperate enough. Shit couldn't have happened at a worse time. I just got back from Japan and have job interviews this week but now no car. Ugh....
