Shadowplane676
So I did find that there were three additional tables that are the ones mainly affecting AFR on full throttle. They were specific single row tables for WOT conditions. I adjusted those to mimic what I was targeting in the primary 3D tables and was able to see a change in logged AFR.
I was able to log about 5-6 WOT pulls and saw at most 2.5 KR (with the corresponding change in AFR as the ECU flipped from base WOT AFR targets to the Knock AFR targets). Generally my knock was quite contained, however the odd higher knock was as best as I can determine, a byproduct of heat soak/increased BATs into the 150* or higher range due to heat soak.
Additionally, cruising state still saw BATs around 100-110*. While the TMIIC may be ok for staving off obscene BATs, to me this is highlighting the fact that a FMIC is probably a good idea. an increased surface area intercooler along with better airflow for heat transfer hopefully will keep BATs down into a more agreeable range.
Lastly, I did try and bump the WGDC and target boost by a small bit to test if I was in the right tables, but did not see a corresponding change in WOT boost logged yet.
