Shadowplane676
I am currently at a crossroads with my speed3. The stock K04 appears to have given up (won't boost past 4.5psi) and all signs point to the turbo (checked WG, BCS, boost leaks etc. and nothing showed up). I wanted to go with a CST4 for some headroom and not turning into a hairdryer at higher boost levels, however Corksport replied to an inquiry of mine that the CST4 is not a drop in replacement for the stock turbo from an ECU perspective.
I wanted to see if anyone had tuned a CST4 on either Mazdaedit or Versatune. I did see the Big Turbo thread, however it looks like that is primarily a base map to get someone to a dyno for further tuning (great thread BTW). Additionally, I have seen very little in the way of knowledge base items around for the Speed's ECU configuration and tuning. Coming from a standalone MAP-based ECU background, I am working on figuring out how the Speed 3 ECU differs and what tables affect the engine in the ways I am used to tuning. If anyone has further thoughts, resources or information along these lines' I'd appreciate it as I have spent quite a bit of time searching with no real luck. If I can't get up to speed appreciably soon, I will most likely end up rebuilding the stock K04 for the time being in order to get the Speed3 back on the road.
Regarding my choice of interested tuning options, I have a stable of 3 Mazdas that would benefit from the level of access a tune program would provide. I am not considering COBB at all due to the price per vehicle and lack of support for 2 out of 3. I am hoping that with this newer forum, there may be some knowledge floating around that was not particularly appreciated elsewhere. Thanks!
P.S. - I am working on recreating my build diary from the now defunct mazdaspeedforums.org site...
