^^^ thisOh you will, if not set up in ATR.
And it is safe to say all the crap that is usually flung through it, will get backed up onto the piston.
Correct. The default, unenergized EGR position is closed. That's why I run unplugged most of the time. To me, I see no need to EGR delete unless you need the extra room for a bigger turbo, like a MUCH bigger turbo. My EGR is still intact with my BNR S3.Correct me please if I'm wrong, but with the EGR piston closed, there is no flow. Without flow, there is nothing to carry the junk to the piston.
There is some small flow from IM vacuum/boost cycles plus vibrations, so junk can be carried down from EGR tube.Correct me please if I'm wrong, but with the EGR piston closed, there is no flow. Without flow, there is nothing to carry the junk to the piston.
