ExtremeCaliber
Heya, so it's a bit of a weird one, this noise only occurs when going up hills. When there's a straight there's hardly anything. I've recorded a video for better explanation:
Before said noise used to go away. Things related to this that I've done would be:
Besides that I'm not sure. There is no loss on engine power, it doesn't bog down when you hear the noise. No play in steering, no vibrations other than the noise you hear. At the end of the video I talked about joints but I'm not too sure about it anymore. The noise comes mostly on the passenger side. Just wondering if someone may have come across this before, as noises are kinda hard to describe and search for in text form. I've inspected the suspension and everything seems to be fine, the wheel bearing and tire rod test of wiggling the wheel while it's on the car results on no play either.
- Koni Orange struts
- CV axle change
- wheel bearing's on all 4's
- brakes and rotors
- Rims are the 18inch Rx8 ones
