Hello guys, first of all, I am David, I am from Spain and I own a Mazda 3 MPS (Mazdaspeed3 Gen1)
I am needing some help. My speed3 gen1 is smoking (I think oil, but maybe water?) through exhaust, i think only is in idle and after 2 minutes of start the car. And AFR is around 14.4/14.5 instead of 14.70 like always (I don't know if it's related. Don't know if burn water or oil can drop the AFR, or O2 sensor is dirty).
• I am running straight pipe since the turbo, but I keep the last small muffler.
• Turbo rebuilt with Melett CHRA 1000km's ago.
• No oil inside turbo intake housing.
• No oil in the recirculatory pipe between the rocker cover and the intake.
• Compression test 180/185/185/182 psi (Made the test 4 hours later of turning off the car)
Maybe turbo needs some back-pressure and straight pipe is working bad?
Maybe defective CHRA and burning oil through turbo seals ?
Maybe PCV is working bad?
Maybe valve stem guides?
Maybe bad head gasket and burning water? (I think this is not possible because compression test results are good)
In the second video, I give it a small push to accelerator, look all the floor splash, and exhaust have a lot of tears, I think it can't be condensation because is not winter, and sometimes the smoke smells bad.
Thank you all
Thank you all
