Could you just go honduh and put some washers under the hood hinges to raise the rear of the hood and inch or so?
Umm maybbbbbbeCould you just go honduh and put some washers under the hood hinges to raise the rear of the hood and inch or so?
I'm kinda happy/disappointed about hood clearance. The Cobra intake is a bit taller than the rest of the manifolds. I'm going to most likely run a cowl hood or so. I will see if I could lower the subframe a quarter inch and cut the middle hood bracing.
So instead of the intake going towards the front of the engine, to have it towards the back of the engine?...Since you will be using a cowl-induction hood... Use that high pressure area at the base of your windshield for your cold-air intake. My .02
Think so? Doesn't seem to be the case with my FMIC. After sitting at a stop light for a while, it takes a good deal more than driving at 10mph (and for at least a few minutes) to bring BATs down to what they were when I rolled up to said stoplight. Then again, apples and oranges; though both are heat exchangers. Maybe if I had a LTA intercooler it'd be different.Fans dont matter once the car is above ten mph or so.
Yeah, it makes perfect sense to me that cars that basically never stand still (i.e., race cars) have no need for radiator fans. All the fans do is simulate forward motion in a stationary car.I dont think so i know so. Put your hand out the window at 10 mph and put your hand "carefully" behind the fan when it is running. Which one is moving more air.
Your bats dont drop immediately due to the heat which is retained within the piping and core of your intercooler. If the fan was as important as you think the intercooler would never heat up while stationary
As another data point most purpose built race cars do not have fans. Since if running and competing they should not be stationary a fan is not needed.
If your bats are not dropping quickly start a new thread with pictures and lets figure out why.
I'm doing most of the fabrication myself so saving me LOTS of money. I also did a full gasket rebuild and lots of new miscellaneous parts. So far a little under 3k? Probably another 2k to finish and another 6164839209386k where I want to have it at.this is dope and a steal even for an NA... i just got an NA myself... whats it costing u roughly to do this swap? looks like uve got a screamin deal on all the big parts. i wanna see if this will be comparable to a 1.8 swap with bolt ons
What do u need to fab? Motor mounts and a cross member maybe? Headers and exhaust I'd assume as well?I'm doing most of the fabrication myself so saving me LOTS of money. I also did a full gasket rebuild and lots of new miscellaneous parts. So far a little under 3k? Probably another 2k to finish and another 6164839209386k where I want to have it at.
Did sell about $1500 in Miata parts I wouldn't need.
Something I'd think about when the times right... ms6 nerds to get done first and running correctly then I'll look at wat ill.do with miata... kinda just want an NA with torsen rear end, rx7 t2 brakes, 99-05 1.8l with bolt ons. I think tht would be a legit setup on an NA.Pretty much modify the stock front subframe is the cheapest way to go. I got some headers that would tuck closer to the engine instead of Monster Miata ones that go around the control arm. Exhaust has to be custom as well.
Monstermiata.com has the kit if you plan on going that route. I'm getting a few parts from Martin (clutch hydraulics and axles). He's a really cool guy.
It's a very big process, but I like challenges![]()
You should definitely join v8miata.net if you're considering to do a v8 swap. Lots of info on that site!
Yea this Miata had a torsen and it was so much fun at stock power! Definitely will get another Miata and have a badass suspension.Something I'd think about when the times right... ms6 nerds to get done first and running correctly then I'll look at wat ill.do with miata... kinda just want an NA with torsen rear end, rx7 t2 brakes, 99-05 1.8l with bolt ons. I think tht would be a legit setup on an NA.
Sent from my SM-G930V using Tapatalk
