Awafrican
Moderator
JBR SSP, third was poop definitely missed that before I did solid shifter bushings now I can't recall the last time I missed it. I've been tempted to get the CS shifter assembly because of the adjustable height (would get JBR but doesn't have height adjustment iirc).What short shift plates are you guys using?
I have Ford fluid, damond plate, and stratified extender and have no complaints. I used to have the original jbr plate and it would miss going into third all the time
The plate plus extender gets me basically back to stock throw but much higher and easier to reach
Best mod I made was to grease the shifter pivot.
Oh and I have solid shifter bushings but I assume everyone has those at this point
Also running redline MTL fluid, I'm gen 2 thinking of swapping to tribodyn
