andale927
Silver Member
Previous mod list:
Power:
BNR S4 v2 Turbocharger
JBR 3.5" Aluminum Intake
GFB Respons BPV
Depo Racing Catless Downpipe
NGK Iridium 1 Step Colder Plugs
Bosch 3 BAR MAP
JBR 3 Port EBC
Treadstone TR8 Intercooler Kit
Autotech HPFP Internals
Ultimate Racing Catback
Freektune E30 Mix
Devils Own Methanol Injection 5GPH Nozzle
Custom Tru-Cool Oil Cooler w/ Therm
~400whp @ 24PSI Boost
Handling:
KW V3 Coilovers
Corksport Front Camber Plates
SPC Rear Camber Arms
E46 M3 Front Endlinks
Whiteline Rear Endlinks
Wilwood Dynapro 6 Big Brake Kit w/ 2 Piece Rotors
Wilwood BP-20 Pads Front
Hawk HPS Pads Rear
Stoptech SS Braided Rear Brake Lines
Michelin Pilot Sport 4S 235/40/18
Damond Transmission, Passenger, and Rear Motor Mounts
Damond PCV Plate
JBR Weighted Shift Knob
JBR Shift Bushings
JBR Rear Sway Bar
Damond Short Shift Plate
Corksport Steering Wheel
Avid.1 AV-20 Wheels 18x8 +35 Wheels
Figured I'd start a build thread for this since the excitement is getting to me and I need to tell someone lol.
Purchased an Full Race EFR 7163 kit in September 2018 only to do a compression test right after and get the following results:
Cyl 1 190
Cyl 2 190
Cyl 3 165
Cyl 4 190
I was really looking to push the turbo so figured I'd go all out with a built motor. Purchased an SP63 Stage 2 off the shelf build a few months ago and I should be getting it any day now.
Goal with the build is a car that can make big power on the street along with track days, while still spooling well enough to be competitive in Autocross. Goal is ~550whp.
Parts I've ordered so far:
FR EFR 7163 Kit
SP63 Stage 2 Build
South Bend S3 Enduro Clutch Kit
Replacement Slave Cylinder
SP63 6th Port Kit
Aeromotive 325 LPH Fuel Pump (Figure with an unregulated fuel setup any extra flow will help with making my goal numbers on E50)
Eric Yarbrough Wire Tuck w/ PI Dongle
JBR Under-Route Hot Side Kit
CS 3.5 Bar MAP
CS Injector Seals
JBR Oil Pan Baffle
CS Intake Manifold (If it ever goes in stock again...)
Koyorad 25mm Radiator - Already installed this, was a cake walk without a motor in the car.
Some pics:
Before anyone says anything... I am not rich, just run a side business solely to fund all car related activities. Having a monster MZR build has been a dream of mine since I was a kid in highschool nearly 10 years ago and joined the Mazdaspeedforums.
Power:
GFB Respons BPV
Bosch 3 BAR MAP
JBR 3 Port EBC
Freektune E30 Mix
Handling:
KW V3 Coilovers
Hawk HPS Pads Rear
Damond PCV Plate
JBR Shift Bushings
JBR Rear Sway Bar
Cyl 1 190
Cyl 2 190
Cyl 3 165
Cyl 4 190
FR EFR 7163 Kit
SP63 Stage 2 Build
SP63 6th Port Kit
CS 3.5 Bar MAP
CS Injector Seals
JBR Oil Pan Baffle
Some pics:
