jdab555
Starting this thread to keep track of what I am doing and to solicit advice and feedback for planned upgrades / unplanned problems.
Bought in January 2020 from an acquaintance of mine from college, who put in a built bottom end with a stock head. When I bought it, compression tests showed 180 across the board, and the engine had about 20k miles on it. The engine is probably a bit over 30k miles now. Not shooting for big power, immediate goals are all around reliability / driveability.
Edit: Added in some pics, notice the wheel lift, suspension is trash for autocross.
Current Baseline:
Current Baseline:
- Miles on chassis 115k, miles on engine ~30k.
- Built bottom end bored .020 over (Eagle H-beams, Wiseco 88mm pistons, Mahle Clevite Main & Rod Bearings, H11 head studs).
- Stock k04 (missing a downpipe stud) - ~40k miles
- Stock-sized TIP/SR intake
- Full exhaust
- Port/polished IM
- Corksport TMIC
- Freektuned
- Dual Catch-cans, Damond PCV plate
- Corksport Struts & Shocks
- Eibach Pro Kit Springs (ew)
- Stainless lines front/rear
- 9/5/21 - Plugs @ 114,750
- 9/5/21 - Compression Test - 180 all +/- a couple points
- 7/21 - Brake Fluid flush
- Suspension is garbage
- Plugs didn't look awesome at last change, though that may have been due to high-heat autocross days.
- Piston closest to the passenger side looks "damp" compared to the others which show no signs of moisture.
- Need to clean up the engine movement somehow, new bushings somewhere
- FMIC
- Coilovers (BC Racing? FA?)
- HPFP Cleaning
- Injector Cleaning and Seals
- 3" Intake?
- Oil cooler
- Hood vent
- Paint Care - Correction, coating
