gotovato
Studs are just whatever comes in the hub. Not sure about grade but I’m guessing they’re OK since the hub fails before the studs?On another car I smeared the face of the hub with antiseize because it would get so nasty. I'm an idiot though too and was forgetting that the brake rotor would be mounted right there a solid wheel spacers would probably be overkill.
I wonder what grade the studs are and if they are maybe not quite strong enough to keep everything 100% tight on the track
I’m thinking to try buddies advice. I ordered a little tube of silicone grease. Was thinking to use copper anti seize since I have that but don’t want it making a mess everywhere.
I’ll go lightly with the grease just enough to prevent rust. Hopefully that helps with something
