So do you have four pistons now too?
How much does that pin weigh? Looks heavyThat's wild to me because these are the pins in my engine (I estimated redline to be 9k):
They sent me the same pistons again with the heavier wrist pins.So do you have four pistons now too?
Wiseco Wrist Pin, 0.8661 in. Outer Diameter, 2.3600 in. Length, 137 gramsHow much does that pin weigh? Looks heavy
Thing with the uhaul is it has like a spot where it wants the tires. Theres a notch you gotta go over then there’s a stop. Also the built in straps only go so far. I could’ve maybe had it 4-6” further back but that’s about it.Civic is too far forward on the trailer.
You want to to have the weight over the wheels with the tongue being a little hevier
You could try loading the car backwards but that would likely be too far in the other direction
