Thanks for plugging away at those number for me.
I plan to run +2mm exhaust valves with port work to accommodate them to get more exhaust flow.
My split duration of 8deg is less aggressive than stock (16deg) to be more balanced flow of exhaust vs intake (your grind has no split with equal intake and exhaust durations of 224/224).
My logic behind more exhaust duration and flow is to spread out the time it takes to get the exhaust through the turbine housing instead of trying to force it through in a quick bursts. Now I know exhaust velocity helps spool the turbo and lengthening the exhaust duration might make it more mellow, but on the flip side opening up the exhaust earlier (hopefully not too early) might be letting out some residual combustion similarly to anit-lag, but much less aggressive, so maybe spool wouldn't be infringed? My other logic is the intake side has help getting air in, so increasing the exhaust flow will help with getting all that extra air back out.
