Fstrnyou
Since you can theoretically push the IVC event later with more boost...I'm now curious if the simulator will show similar results with and without full VVT advance. If VVT top end HP is still higher than non-VVT, the difference should be less...in theory.
As stated several posts ago, I typically run 28psi on the CS turbo...BUT it's out of breath with the mods I have. I'm betting larger cams and "slightly" better flowing head may limit my boost to mid/low 20's.
I'm guessing you're using DynoSim for these? If I had a copy, I would literally lose sleep playing around with that program night after night.
