Hi so im pretty new to the forums so im just wondering as to what else i can check and such about boost leak. I have a 2007 mazdaspeed 6 tuned by drama. Before i installed my 3.5 inch intake and corksport fmic i was running 24psi but after install erik from drama said that he upped my wastegate duty to 45% and so but couldnt give me what my peak boost is at. Apparently i should be well about 14psi. I did smoke test and boost leak test and found out my bov and ebcs were leaking so i replaced those. Hose from the intake manifold that goes to OCC was also ripped so i replaced that as well. My boost leak test was at 25psi but somehow still goes down by the tiniest bit but i was thinking its because it leaks out from the vvt solenoid gasket. Yes i pinched the line rhat goes from intake to valve cover. Pressure tested the wastegate and it moves smooth and goes back. Im honestly confused at whats going on and drama is basically giving me shit for not boost leak testing the car before we started tuning... I need help what else to check i brought it to a shop just waiting for the car to come back. Thanks
