JohnnyTightlips
Motorhead
Lol those mini van drivers, always wot all the time.Log taken slightly uphill; might actually be right at 200 to the wheels now.
BATs start in the mid 120s and end up right around 160 so those ducts can't come fast enough; I know it's costing me power/flow. Also, not having the under tray (at least the front part that seals up the front part for the radiator) is hurting ECTs as well.
Overall, looking a bit better:
Log Notes:
1. Need to add about 6% fuel above 3.2v and re-smooth it (triple point comparison like always).
2. Need to aggressively dump timing below 3500 at higher throttles because it's costing me spool and torque.
3. Hitting 80% IDCs at 5800 so really, really need to open up some fueling headroom here too; next trip out, I'll be swapping to 50/50 and watching for knock (none currently even with 214 ECTs and 160 BATs)
4. Peak HP @ 6k is with 9 degrees timing. I can probably add more but I don't want to do that until I max out this WGA after the E mix swap.
After all that is done, I'll probably run it like that for a while as the next steps are rather expensive and I have a fair bit of debt to pay off.
Revised the to-do list:
Full wash and detail - Primary wash done so it's mostly clean, but full detail coming from a buddy of mine in trade for a watercooled GFX card.
New windshield wipers - Done
Delrin shift knob - Arrives tomorrow (thanks @Maisonvi !)
Shit for trans fluid and oil change - Arrives Wed
My left arm is sunburned as fuck so got one of them sleeve things showing up wed. I'd like to avoid skin cancer if at all possible. lol
AC filled - Next week
Sways greased - Next week
Headlights adjusted - Next week
Smog check for lols? - Next week
TMIC duct nut, flanged - En Route
Reinstall TMIC duct scoops - En Route
Headlight braces - En Route
Coolant fittings for turbo (need to reroute before it cooks) (@VashEXE )
Custom TMIC or chemcooling? (Decision then implementation)
ST intake mani with custom config? (Decision then implementation)
Meth parts
6th port
New 360 dash camera and seat mount?
New tablet for central mounting?
Also need some kind of heat resistant padding or something to keep the CS catback from banging the frame under certain conditions. Pretty annoying.
Oh and won my first "race" today. Pulled up to a light that I new was going to turn very soon so hopped a lane over that was unoccupied in the hopes that I wouldn't have to stop (no AC still) and homeboy in his minivan fuckin sent it right as the light turned green (basically just as I stopped). He was quite upset that I gave him all 8k so he returned the favor with ye old middle finger when I turned at the next light.
@Maisonvi The only issue I had with the shift knob is that you can't use the knob to tighten the extension; I had to wrench the extension for fear of causing the knob to crack/split. It's something I shoulda thought of originally though, so no fault on you for that. I'm also not sure how deep the hole is so I'm considering getting some kind of allen head plug to insert into it to give me a more definite stop so I don't fuck this thing up.
Otherwise, it's perfect. Feels good in the hand, and takes the right amount of effort to shift now without feeling sloppy; can't just poke it into gear anymore (a good thing)..
