Effects of high eth content on fuel level sensor
I ordered a gen 1 level sensor to compare and see what exactly is different between both gens.
Sent from tapioca
So far it's been impossible to get a hold of a gen 1 sensor as they're obsolete now. For now I removed the positive terminal and soldered it completely with high lead content solder. I think I'll add a dab of the EZ TURN stuff on the contact pad and a glob over the terminal itself as well.
Sent from tapioca
I ended up cutting the terminals off and soldering the wires directly to the board. I went ahead and insulated them with the ez turn stuff. Crossing my fingers here for us gen pu guys. The 1st replacement board I pulled out failed in a similar mode. Purely from the positive terminal.
Sent from tapioca
Kind of a shitty way to have to do this but seems likely to survive so long as the solder doesn't lift the traces off the plastic or break loose due to vibration.
Is there any way to adapt a different fuel level sensor into the housing for your car?
I know there are a ton of Flex Fuel GM vehicles on the road. Maybe an Equinox or Malibu would have a tank in similar size.
There was mention of a sensor from a 2012 Lincoln MKZ that could be used. I haven't gone down that route yet.
I'm looking at parts on Rock Auto while on the shitter at work
Motorcraft ps603 is for a 2016 flex fuel focus and looks similar to the ms3 assembly. I can't get good enough pictures to confirm but they look really similar
You might have better luck since you have spent a lot of time looking at the stock part
Could always see if it's in stock locally and take your old one in to compare
That era focus is on the same platform as gen 2 so you would think they would be similar
I found the 2012 Lincoln MKZ sending unit and it appears to be almost identical to how the stock sensor mounts to the basket.
But this was just a suggestion from littleloogy.
https://www.myautovaluestore.com/motorcraft/ae5z9a299e-mop-ps435
@Easter Bunny heres a photo of the suggested PS603 sensor. It looks like it shares a similar board, but the whole plastic mounting piece is different. https://ford.oempartsonline.com/oem-parts/ford-sender-assembly-fuel-tank-ps603
Now this whole fuel basket assembly may be an option. This is from a 2016 Ford focus SE with flex fuel capability.
https://www.tascaparts.com/oem-part...vPWZvY3VzJnk9MjAxNiZ0PXNlJmU9Mi0wbC1sNC1mbGV4
For 84 dollars it's probably worth grabbing the whole basket to compare/cannibalize
Pay attention though I noticed there were different art numbers for flex fuel and non flex fuel cars
I just noticed the guide pins are not exactly 180 apart from each other like gen 2 baskets. no go. abort
So i have been doing research on the mercury fuel level sensor, and it shares the same part number (AE5Z-9A299-H)
with the following vehicles. Some are flex fuel compatible. I am assuming these specific level sensors should be able to take full e85.
From Tasca:
2012 Ford Fusion SEL 3.0L V6 - Flex
2011 Ford Fusion SEL 3.0L V6 - Flex
2011 Mercury Milan Base, Premier 2.5L L4 - Gas, 3.0L V6 - Flex
2010 Ford Fusion SE, SEL 3.0L V6 - Flex
2010 Mercury Milan Base, Premier 2.5L L4 - Gas, 3.0L V6 - Flex
I talked with the lead electrical engineer here at my work. He does all the heavy work on all our power circuit boards. He recalled a time when he repaired fuel level sensors in the avionics industry and suggested completely coating the wires direct to the board with 3M scotchweld 2216. We use this stuff here at work on a daily basis and its basically like jb weld.
Amazon product ASIN B000WXHHTW
