Okay I'm starting a new thread becuase I've learned alot since I first got my hatchback. I have a 2007 mazdaspeed 3. It has a no name Sri with straightener, Autotech internals, just did a fuel pump seal kit, a tubular header, aluminum flywheel, reproduction factory turbo, egr delete, deleted second cat, and a V3 Accessport. Alot of the parts were on the car when i purchased it. Just replaced the spark plugs with factory densos gapped at .27. I have no history over this car other than the engine is under 50k miles old. I've had an on-going issue. I've learned more details over about 6 months of dead ends. Basically I'm having knock conditions with no correlation to any other values except for rpm . I get KR upwards of 8 degrees above 5k. The car falls on its face at 5k. At idle my LTFT are around -11 to -14 although normal (-.16)under any load. It will not spike above 14psi no matter the tune. My data logs seem that it hates anything close to 10 degrees advanced ignition timing around 5k at 13psi. Id like to also mention my second oil change (around 3700mi) came with a golden stream of metallic flakes. I since changed it early at 2k and little to no flakes were present. It has a small audible miss fire at idle. The tubular manifold warms up consistently on each runner. Im almost scared to do a comp test. The engine pulls very very well until 5k. This is supposed to be my college car and fall is just around the corner. I will be 4 hours away from my shop and tools. I'd love to get this fixed anyway possible. Im running the only 91 octane fuel that is even remotely close to me (another 91 pump is an hour away).
These data logs are on COBB OTS Stage 1 plus SF map for 91 octane.
