Cfoldone
Silver Member
		Thank You for bringing this up, I again looked like a idiot making a stop/turn and face-plant engine cutout / recover a couple of days ago.
The use of a variable resistor pot will cause a fault. The variable pot will reduce the voltage but that is not what the logic uses to define
steering shaft movement. The logic has a high or digital value =1 of 4.00 - 4.75 volts, low = 0 of 0.25 -0.75 volts. Think of a reading that
has the minimum and maximum values that define the logic states of 0 or 1. If input voltages are outside of those voltage values per logic
rules.... That is a undefined state ie.... a fault in the ability to read a logic 0 or 1. Then the logic will create fault condition thinking a bad steering sensor, connection, wire. The correct signals also have phase (timing) in relation to difference between terminals ACED which
defines the direction, speed of the steering shaft turning movement.
Now the pot could of course be adjusted to create any voltage to one of terminals ACED to cause a fault. Same as a switch.
Would that fault code be different then current practice of a switch between terminal A (light blue) that is my question.
CAN bus users (modules ask, watch for data) see the general fault code broadcast would cause all modules to ignore the bad data, some kind of spoofing of the data stream would be needed to allow only one or other modules to ignore the fault.
The variable resistor pot would likely do same switch modification result, unless the voltage causes some undefined ECU condition.
The switch method appears to have no lasting drastic effects?
Feed back from current users of the switch option?
