NinjaCustoms
NEW UPDATE - DETAILING PART I- GLASS
I decided ti give car a good clean , it was not in bad condition but paint is slightly scratched and all glass surfaces are strangly matted (maybe from paint dust from painting the bottom). This dust is hard to remove but there are two ways . Use special polishing compound like 3M or special oxide dust to polish the surface or use polishing paste for headlights. Put the compound in preferred way, directly on glass or onto the pad. Spread the compound and usung medium force start polishing the whole surface. Then switch to harder pad and using less force but faster speed polish again. Lastly use polishing cloth pad (furry one ) finish surface. Grab microfiber towel and remove excessive dust and pase from surroundings. Last step is to ceramic coat surface to prevent such dust from ruining glass (but surely don't paint near car or cover everything including car if need to paint nearby.
KEEP IN MIND that best results are achieved after a great wash which in my case was
1. APC strong 1:5 and clean every corner using detailing brush
2. Rinse
3. Active foam to de-acid paint
4. Use special sponge or washing glove to clean everything
5. Pressure washing
6. Clay bar whole paint
7. Drying using firstly, special blower to remove water from gaps and secondly drying towels.
Let the car dry for a while
That was day one
Today i spent whole day polishing headlights, mirrors , taillights and glass.
Then ceramic coated them.
In next part I'll do paint polishing in three stages , coat rims , and protect tires with tire gel .
I cleaned whole interior in every possible way wich mainly took whole day .
As a result car is brand new on the inside.
Every spot was cleaned including door insides , gas cap.
Removing some elements was needed such as seats and rear couch.
Part II - paint correction soon.
2. Rinse
5. Pressure washing
That was day one
