DustinDriver
I can move it with my finger. Not saying it is actually working. And I guess I can say it's not being that indont hear is blowing off. If it does its not much. Lol
True. Only thing there is I didn't change any of that. I guess I'll do a leak test. If I don't find anything there, I'll get a new bov. And if that's not it I guess this new turbos wastegate isn't capable of handling more that 12psi. Loljust because it moves doesn't mead that it is plumbed correctly
Not.much room to do all that with it on the car. Lol its a new ebcs I'll check that too.If the ebcs is working correctly the wastegate wouldn't be that big of a hurdle
If you still have the old turbo you could switch the wastegates
I did a leak test. It dosnt hold air but I can't find where any is leaking. through the throttle body I guess. The ebcs I got isn't the same part number is a Dorman 667-104. Maybe it's not the same?Not.much room to do all that with it on the car. Lol its a new ebcs I'll check that too.
Im looking at the same pictures I've been looking at for a week. I see the line going from the bottom of the wategste to the compressor housing. And it looks like the one from the top of the wastegate going to the ebcs port closest to the connector. I can't find a picture but assume the Second port" closest to the firewall goes to the intake " post MAF"Bleed.
Intake (post MAF) -> EBCS -> WGA -> Compressor housing.
Edit:
Stock EBCS is 2 port normally closed IIRC.
Stock WGA has 2 ports on it (Image search for the stock turbo and you'll understand)
But I really feel like I either have something crossed here. My new ebcs isn't working , or I have a cracked line. I will replace them tomorrow.Im looking at the same pictures I've been looking at for a week. I see the line going from the bottom of the wategste to the compressor housing. And it looks like the one from the top of the wastegate going to the ebcs port closest to the connector. I can't find a picture but assume the Second port" closest to the firewall goes to the intake " post MAF"
I tried that today. Pulled a valve stem into. Pvc cap. Put that where the filter should go. Pumped air into it and didn't hear any leaks amywhere.tried soapy water. Nothing. Should I block off the throttle body side also? I could release the air with the bov but if I turned the pump off there wouldn't be any air at the bov within a couple seconds.You have a leak and need to find it, soapy water! Could be the bpv leaking too
Do I need to block off the throttle body end? Or just the intake to valve cover line?I tried that today. Pulled a valve stem into. Pvc cap. Put that where the filter should go. Pumped air into it and didn't hear any leaks amywhere.tried soapy water. Nothing. Should I block off the throttle body side also? I could release the air with the bov but if I turned the pump off there wouldn't be any air at the bov within a couple seconds.
You are doing yourself absolutely no favors if you ignore this.Start over. If you can be tuned, you can log. Post a WOT log of 3rd gear, include ALL columns.
True.You are doing yourself absolutely no favors if you ignore this.
I was thinking maybe it's not closingTrue.
