Raider's Neverending love/hate with Christine
  • Watchers Watchers 37
Looks slow
And what the hell Mr fatwa against side mouldings has bumper guards. Rip those nasty things off of there now!!
Out of curiosity, where is the RTV applied when putting the valvecover back on? Can't seem to find that anywhere.
All seems to be well! did 3rd gear 3-5K, a pair of maf cals and idle logs for Will. Drives great overall. Will be getting the brakes and the clutch like pressure bled at work and an alignment once I get my revised map. Hopefully there are no issues!
Brakes are bled, alignment is set. But the hate continues. Old oil leak continues. Don't know where. But apparently it's there. All that has messed up the starter which will not always start. Will get solenoid click. So that is happening. Gonna look into a starter now. Then on the way home got a stupid CEL. Too tired to check it but damnit.
If starter isn't new. And want to try a experiment, use something... Hammer but access is tight so a long metal rod, give the starter a tap. Sometimes motor brushes get worn, stuck in holders. Or solenoid high current motor contacts get a oxide that won't allow current flow. Sadly our starters are buried... Mazda way
Your troubles are shared all by all who read. Thank you for keeping us informed.
Yeah the hammer trick has been out a whole. It was caked in sludge when we took off the manifold. Sucks.
