Why didn't you just go with a CS throttle body? it's a 72mm PnP. I think the most you would have to di is possible make an adapter plate for it depending on your bolt pattern.
I'd have to make an adapter plate anyways. I'm not spending 350$ on a TB. This TB was 60$ on rockauto and is 70mm.
PnP doesnt really bother me either as I'll make everything PnP myself.
I paid 20$ shipped for mine and it came with the harness so.........I will let you know if I get an adapter fabbed that works well. @Maisonvi would be doing the hard work for me.
AEM 50-1215 E85-Compatible High Flow In-Tank Fuel Pump (320lph), that's a direct drop in?
Great to know as it is a decent amount cheaper than the drop in aeromotive and is a trustworthy brand.Correct
The assembled photo with the whole pump laying on its side is with the AEM pump installed into it.
Also, Heads up, you'll want to switch to VT from Cobb if you don't want the ridiculous on/off throttle jerking from fuel cutting well before the throttle plate closing on decel.
Unless Cobb has released these tables. (roads like tail of the Dragon would be horrendous with the Cobb tables)
Sad to see you giving up on that intake mani. What was the mani originally flanged for?Yea, this IM venture is turning out to be more than I wanted it to be. Not even the Chrysler TB matches this IM.
I'll probably just send it on the OE ported IM and see where that leaves me at this point.
I could chop the flange off and weld a new TB flange onto it. But then in already in further than I want to be on principle lol
Lol, I saw that a few weeks ago. It has been pre-modified but they are trying to sell it as new. I wonder if the TB cable has also been pinned. With that spacer @Sho showed before you could bolt it right but to stock flange.I have no clue at this point. I've seen GM/Buick, CX 9. At one point I was told a mustang GT. No clue.
@Sho this looks oddly familiar. lol
View attachment 9633 View attachment 9634
@KingScumbag what oil drain did you make for the BNR? I'm finishing up my S4 install and not loving how the OEM drain had to fit, might have to explore other options later.
