Shedbuilt and Scumbuilt
KingScumbag
Welp, forums are a dying platform unfortunately. Hate to say I've been one to get caught up in work and social media platforms. They need to make a comeback and would like to do my best to get back on even if it's to BS. Been through so many different set ups and forgot how long it's been and how fun it was to build a diary for everyone to see.
That being said, in all the years in the community and all the gone dark days have past it's due for a build thread finally!
Car:
Black Mica 2007 Mazdaspeed 3 GT
Powah:
#Shedbuilt
Manley 88mm platinum pistons
OEM Main Bearings
Clevite H rod bearings
Manley H-Beam rods
BSD
CPE seals
Shedfabbed oil baffle
Stock port head and valvetrain
Freeky Headstuds
AT HPFP
Ported OEM IM
DM PCV Plate
DM RMM, TMM, PMM
DM EGRD
FJ Exhaust Manifold 44mm Tial EWG
T4 Flange BNR S4
FJ 3" Downpipe
HKS Catback
Under route charge piping
Small battery tray and 51R
3" Freektune Intake w/aem filter
Custom mounted dual vented 4 port catch can
Re-laminated and re-insulated heat and firewall/exhaust tunnel.
Suspension/Handling/braking:
Upgraded RSB
SPC Adj. Rear camber arms
Koni Yellow Shocks
Swift Springs with rear dragbags
Stop tech slotted Rotors
HAWK HPS+ Street pads
Stoptech braided brake lines
Upgraded HP PS pump lines
Shirt throw shifter
Car is dyno tuned by Freektune sitting at
337/332 on pump and
375/357 on E25
In the worx:
DM PI Plate
Injectors (need to get)
Radium Surge Tank (need to get)
Hoses and fittings (need to get)
SS 4 injector controller
KMAC IM
Upgraded 75mm Mustang GT TB (need to get)
Plans it to run PI off of the HPFP feed. Stock ITFP supplying a dual port Radium surge tank with AEM 50-1000 pump to supply PI rail. Simple and effective setup. I've always been content with the slow ass conservative power. Plans are just 450ish to be at a happy median.
Ran the car on the drag strip for the first time ever this year. 13.2 @ 111mph. Wheel tire setup was street tires and heavy reps. That will get you almost 3 second 60fts lmao.
Will update with photos when I figure out how to do this forum thing again.
I picked up some slicks and skins for cheap from Justin. Gotta shave the calipers down and grab some spacers. Should be ready for next season.
Need to work on LC and FFS as I've honestly never used either lmao.
With FFS the best advice would be to consciously take your time with the shift. You don't need to slam it F&F style (because that'll make you more likely to miss shift).You'll get faster as you practice and since the car is tuned to not rev to the moon when you FFS you don't need to worry about rushing.
I see your looking for a radium surge tank. I have one I'm not going to use. Let me know if you were interested
Yessir 5mm... Was gonna use with stock wheels but said nah.
Figured I'd offer at least :P
Yea, I'll def grab those from you @_Mazdarati
Trying to get this photo thing down. Pics of pulling motor.20160629_133328-1.jpg 20160707_103656.jpg 20160629_134749.jpg 20160706_102601.jpg 20160706_165027.jpg 20160706_165037.jpg 20160706_165044.jpg 20160706_165044-1.jpg 20160706_165047.jpg 20160706_194438.jpg 20160706_190249.jpg
[doublepost=1542724393][/doublepost]Pics of Mil assembly and Mil install20160831_161112.jpg 20160911_193638.jpg 20160924_145816.jpg 20160911_194005.jpg 20160924_151432.jpg 20160916_192701.jpg
Lil sammy break20160903_154325.jpg 20160916_202048.jpg 20160924_182011.jpg 20160903_154332.jpg 20160916_225045.jpg 20161006_214355.jpg 20160905_133218.jpg 20160916_225203.jpg 20160909_210318.jpg 20160917_145437.jpg 2017-02-21_20.10.58.jpg 20160917_183732.jpg 20160924_141715.jpg 20160910_114711.jpg 20160910_114639.jpg
Direct from Mazda. Sold me used, repackaged and butchered mains20160917_195417.jpg 20160910_114652.jpg
Helluva sammy.
I like what you did with the exhaust tunnel...I fucking hate that garbage foil insulation bullshit that the juans came with from the factory.
What caused the fire? Fuel leak?
The EWG tube was rubbing on the HP PS line at the subframe. It had rub/burnt through the line and started spraying the firewall and soaking it with PS fluid. PS fluid is HIGHLY flammable. Once the EWG opened after the leak started to spray the PS line became a flame thrower and the whole firewall went up. That's what prompted an upgraded HP PS line I fabbed up and also covered the line in a heat/fire sheet.
Small update. Was hoping Radium would have a BF sale to pick up the unit with built in regulator.
They did not nor have they since 2015 so I've decided to change things up.
Old plan was
Stock feed>QD fitting at HPFP>tapped over to Surge tank> surge tank to regulator.
New plans.
Plans to use the stock LP supply line.
Upgrade ITFP (still searching)
Quick disconnect to Male -6an fitting on the stock hard line.
Attached to the QD fitting will be a mountable 3 port fuel dist. block with a -6an inlet port.
Dist. Block will be mounted to the FW. From the Dist block two 45° female -6 hose fittings.
One line to the HPFP with a 90° female hose fitting attached to another QD fitting.
Other line will be run to the fuel regulator mounted on the rail.
Still waiting for tommorow to see if anymore sales drop for cyber Monday.
Also will take any insite or recommendations on ITFPs.
Not sure if he will give away their secret sauce but @Farhan@DM may be able to help with ITFP recommendations.
This build makes me happy after another member's build going up in smoke.
I've actually been doing a bit of research. I'm going to get it in the sake of knowledge anyways but it appears the AEM 50-1215 pump are all the same dimensions +/- a few MM from stock. I'm gonna grab one this week.
I've also been made aware that the "Aeromotive 325" is a direct replacement as well.
Things are happening.
All fittings are in. Fuel dist. Block and QD fitting fit together as I had planned.
AEM ITFP. Ordered at 7am on Prime and Was on my doorstep my 1230pm. Lol
This setup could be made much simpler by just quick tapping the feed at the HPFP and running it to the rail. But that's not fancy enough for me.
Injectors are still inbound. I ended up finding a set of 4 bosch 625cc injectors on ebay for 140$
New 72mm mustang 3.7 TB inbound as well. Should match up to the KMAC IM flange. Now it's just a matter of matching the inputs and outputs at the plug for proper operations. May babe to extend the TB harness.
@Atvfreek has a new FPR laying around I'm going to pick up from him and that completes everything.
At some point in the next few weeks I'll be pulling the coil harness to make my own tuck and addition of the SS controller. Talked to Bryan at BNR and I'm going to send the turbo in for a refresh and maybe updated compressor housing.
Started to bring this Kmac manifold down to bare metal as well. Thing has 1/2" thick bondo in some spots lmao20181128_155143.jpg 20181128_164743.jpg 20181108_084014.jpg 20181128_154640.jpg 20181128_155114.jpg
Aye yoooooo!!
So you will not be tapping the HPFP feed? What are you going to use instead?
