BlueSpeed3
Shit I really want to try this stuff but it’s currently unavailable on Amazon and if I order through tribodyn it’s 230ish bucks after shipping and taxesTribodyn he talks about it on the first page see quoted post below
Weird. On mine it says currently unavailable could be because I’m from Canada.
In what way? How does it changeAll ya need to know about gear oil lolView attachment 14137 View attachment 14138
Ive run redline, motorcraft, Torco rtf. This stuff has outdone all of those
It's fine, GL5 has a better shock rating from what I've seen, yes I did see some that talk about not using it but that was more transmission specific than a general statement on other sites. one that's rated for both is good to go, look at brake.fluid dot 3 vs 4 you can put 4 in 3 just fine I know it's not quite apples to apples.Me, I run Redline. It doesn't get particularly cold in Houston. Not very often anyway. I never heard of this TriboDyn stuff. In other threads, I've heard it stated that you should NOT use GL-5 oils in the trans, even if it says it is also GL-4 compatible. And the TriboDyn product says GL-4/GL-5. People here seem to have good luck with it, so maybe it is fine. I'm no expert. But I think I will just stick with Redline.
This is good to hear. My car is waiting for me to pick it up after work with a fresh luk clutch and fidanza flywheel!! Got them to fill trans with tribodyn so I hope I’m not discouraged of how it performs.It's fine, GL5 has a better shock rating from what I've seen, yes I did see some that talk about not using it but that was more transmission specific than a general statement on other sites. one that's rated for both is good to go, look at brake.fluid dot 3 vs 4 you can put 4 in 3 just fine I know it's not quite apples to apples.
also from personal experience redline pales in comparison to the feel I get with tribodyn even in hot weather (I do see 108f here) and spirited driving, yes it being good in the cold is a requirement for me as well.
Redline I always felt as.meh, even liked the Ford fluid better but that's my opinion.
I’ve got the tri-ex 2 so hopefully it treats my gears well. Don’t even know if I was supposed to go with either or.Do you Tribodyn fans also use it in diff and transfer case? They appear to only make their limited slip fluids in TRI-EX not TRI-EX2. I think the TRI-EX doesn’t have ceramic and the TRI-EX2 does. Could you put limited slip additive into their TRI-EX2 gear oil?
You don't need the LSD version in the trans atleast on the speed 3.Do you Tribodyn fans also use it in diff and transfer case? They appear to only make their limited slip fluids in TRI-EX not TRI-EX2. I think the TRI-EX doesn’t have ceramic and the TRI-EX2 does. Could you put limited slip additive into their TRI-EX2 gear oil?
https://www.summitracing.com/parts/...d8DqENlSWXr_tS7OPwiVhmbYJv8rncxhoCPAQQAvD_BwECan't PM anyone yet because I'm new here, but this might be a worthy clarification in case there are others a little confused with the 3 variants of Tribodyn 75w-90. (EX, EX w/ LS additive, EX2 w/ ceramic additive)
According to @Speedie6 the EX-2 (no LS additive, ceramic additive) is too slick for the differential (probably the same story for the PTO), but seems safe to use on the trans. @Sho since you don't use the version with LS additive, and the EX-2 is too slick for the diff, are you using the original EX version with all 3 parts?
Update for this as the Summit Racing link is outdated and still left me confused ultimately.
TL: DR; TriboDyn Tri Ex 2 for transmissions, Tri Ex 1 for the differentials, LSDs, wet clutches, etc
I spoke with Mark Wheatley at TriboDyn, who owns the company, and he gave me the following information:
- The Summit Racing page that @Sho mentioned is TriboDyn Tri Ex 2
- Summit no longer buys from TriboDyn as they sell direct now
- Not marketed as Tri Ex 1 or 2 as it was before Tri Ex 1 was created
- Tri Ex 2
- The original formula
- Ceramic included
- Do NOT use Tri Ex 2 in an LSD or anything with a wet clutch, that's what Tri Ex (1) is for
- Tri Ex (1)
- Created after the original Tri Ex 2
- Originally for Australia as they needed a cheaper priced option that still beat the competition
- All Tri Ex (1) oil has the friction modifier in it
- Film Strength
- Mobile 1: ~6,000psi
- Driven: ~14,000psi
- Amzoil: ~87,000psi
- Tribodyn: ~304,000psi
- Other claims (for their regular motor oil weights)
- TriboDyn to increase fuel economy by 5-10%
- 2-4hp increase potentially
- Mark simply asked "How much would you pay for 2 more horsepower? What about 4?"
- 2024 Valentine's Day Discount
- Use code VAL24 at checkout on https://tribodyn.com/ for 20% off your entire order
