Anyone worried about noise while turning at low speed has obviously never driven one of these with the factory transmission oil.Ah, copy that. Makes sense.
If the EX-2 is truly the same as the old non-LSD-additive 75w-90, then in theory that would be the one to run in an ms3 and the one that is currently in my gearbox. I am still wary/doubtful that it is the case though as the Tribodyn website does have that huge bold red letters warning saying not to use it in anything with an LSD. At the same time, I have heard that using fluid with LSD additives and/or friction modifiers like the EX (1) causes noises and grinding within the diff, particularly when turning or at low speeds, and that those fluids are generally not as good for the transmissions.
It seems like with the info here the question still remains unanswered on the ms3 side of things.
Friction modifiers make the oil more slippery to eliminate the noise at low speed
