@Turbo_Steve had some good ideas for sexy manifold construction if I remember correctly.
@AYOUSTIN as for the effects of turbulent flow... Depending on what sponsorships your school has, you may have access to the student version of COMSOL. If so, that is a very powerful tool for flow simulation.
The air flow will be fully developed turbulent flow. The design with the largest diameter to cross sectional area will flow at a greater rate. So it should make sense that the open runner would have a higher flow rate than the split. The runner is nowhere near thin enough compared to air molecule size to not have an effect on flow.
[doublepost=1458675945][/doublepost]I love seeing tests like this carried out. Always important to have empirical data to support claims. Great work!!
That's exactly what I was wondering when I looked at the numbers yesterday - at what point does the improvement in manifold flow alone become moot? Because at some point the head is going to choke the flow. And then the next question is, at given pwar level how much will the engine take? Since the flow is being interrupted all the time that has to ultimately be the pacing factor and I imagine that improving flow capability of the earlier components by more than 20% above that doesn't yield much.I expect that number to drop after the manis are connected to heads. By how much is what I'm wondering though.
I feel as the balance is probably the main reason for a intake swap for the masses. Only a small percentage can use the larger gains.
@AYOUSTIN Have you been able to find out if you can get your hands on a Cp-E mani for some testing? I am very curious to see how it does against the JMF and how much better if at all the flow is between runners. Then with great hopes Corksport will eventually release there mani for testing also. I would love to see you get your hands on both of those manifolds so testing can be done on the same flow bench so there is no question on flow numbers. Thanks for all your work so far. I was going to go with PNP mani but now I might just pony up and go with one of the aftermarket big boys depending how the rest of the test results go.
Are you possibly talking about the manifold that Steve was working on because that would be awesome! Right now my current goals are to go with a S4 and stay stock block so I just want to get everything I can from the motor. Flow balance would probably be my highest concern so that way every cylinder is getting fed a nice even amount of fuel and air across the board.
How long until you can speak of said manifold? 2 weeks??The only thing I can say about it is no, it is not Steve's manifold. We have not been in contact at all.
Flow balance should be a high priority for everyone no matter what. An engine can only make as much power as it's weakest cylinder so feeding more air to the rest is moot. The only way around it is to have 1 of each sensor for each cylinder but that isn't feasibl.
Exactly, We here this far to often in this community. Hell, were still waiting on @CorkSport to release said info in April ( four days left Man ) On their Manifold.How long until you can speak of said manifold? 2 weeks??
@AYOUSTIN That's good to know I did just see that you are currently a student learning about flow currently so the probability that you have a hand in designing this said manifold that we shall be very happy with is a good possibility I would think! In for more info and a rough timeline so I have a date for info to look forward too![]()
Bump to get some FOST data in here (naked mani, no head as that's already been covered).
Those results are naked with no head attached right?
