Amazon is stalking...Yeah something weird is happening with that link... When I came back to this thread today it just took me to the homepage of Amazon, but then leaving and coming back shows the correct link again. Weird.
Well it is a picture from a plane, they usually have more space in the nose.
Passenger side=red Drivers side =bluesince primary season is almost over, its worth pointing out that the plastic cardboard that most political signs are made out of is a great material for making air blocking panels in the front of the car
Is that aluminum foil?
Aluminum melts at around 650 degrees celsius and any old tin foil you encounter is going to be 1000 grade aluminum, meaning pretty much nothing in it other than aluminum. You don't wanna use this stuff as a heat shield for your exhaust. It would work well as a heat shield in other applications, but your exhaust is something it is poorly suited for.
Yeah, it's true, exhaust manifold can reach 650 C, glowing dark red.I found this regarding that for downpipes
