I've had 2 puck clutches so far and both wore the same way. The pads barely wore at all but the flywheel and pressure plate wore out. These are on Honda B series. I'm sure it will apply here too. Maybe some people can chime in when their's wore out.
1st was a Yonaka 6 puck with stock flywheel. Maybe 10-20k miles?? It started slipping real bad at 4-5k rpm where it was like it went into netural. Upon inspection pads looked fresh and the surfaces were deeply grooved. Attached is a pic of the flywheel I used with a Yonaka 6 puck. I could put the disc in there and spin it with no resistance by hand.
2nd Competition clutch 9 puck with aftermarket oem style flyweel. Still good with little puck wear but high surface wear.
If you google u can find alot of what I'm saying.
https://www.rx7club.com/2nd-generat...-worn-out-all-ready-less-than-2-years-495805/
a quote from above: "you have to keep in mind that ceramic grabs so much harder than a orginic that it will cause the pp and flywheel to wear out fast. an act is a performance clutch, its not made to last forever, its just made to hold."
Pretty much anytime u slip a puck clutch it will wear out the surfaces way faster than a full face. I heard somewhere WOT box doesn't work well with organic. U can overheat an organic but not a puck. Kevlar if you overheat once its toast. twin disc is a joke. U cannot DD it. It really is on/off. Something that would be smoother than a 6 puck would be an 8 puck if u can find one. The less pucks the higher the stage usually. There's also a dual friction where one side is organic and one side is puck. That might be perfect for u lol. IDK If I would trust it myself. I would think I could overheat it.
Well found the dual friction:
https://edgeautosport.com/south-ben...azdaspeed-3-2007-2013-mazdaspeed-6-2006-2007/
People were actually talking about it on the discord. African and Frausty recommended it. Andale uses Stage 3 endurance.
South bend Stage 3 daily. 430 ft lbs
Spec stage 3. Might be gentler than a 6 puck and holds 477ft lb. Full face carbon semi-metallic disc.
https://edgeautosport.com/spec-stag...eting-mazdaspeed-3-2007-2013/#product-reviews
