Maisonvi
Grass-Roots Vendor
Soon (TM)
Edit: Close up of hotside porting, all done by hand:
looks pretty damn good for by hand. nice
Soon (TM)
Guess it's just hard to do with that much dome and not create other clearance issues?Im curious to the pistons with no provisions for DI. Glad this is starting to make headway!!
So, forgive my ignorance/laziness if you already mentioned it, but are using the IE internals alone solution? Or IE + Redline? Perhaps something else?? IIRC, the IE's had some fails/don't have the reliability of Autotechs. I didn't realize they're nearly $500 for the internals:I determined that the fuel efficiency gained from that design was outweighed by the similar gains from simply running higher compression, as well as the overall design goals. I fully anticipate at least stock MPG on full E85 without tuning for it, for example.
So Autotechs + Redline, eh? And that's proven to be a long-term solution if used regularly/in conjunction with the correct oil? I tried to stay updated on the other forum's thread, but honestly I didn't have a vested interest. Between E25 + 100% methanol, I have all the octane/knock protection I could ever want, yet still retain a lot better MPG than 100% E85.I only have Autotechs.
Well, then you might like this new update.
Speed Solutions is going to consume the existing head and set me up with a new one, built *exactly* to my spec. This will put me back to ~12.3:1 compression and that's good enough for me. I'll be boxing up the existing one and shipping it back soon.
