Enki
Moderator
@aaronc7
Might have figured out the boost issue; I think I might have done the math wrong for the additive...
MAPv * Base * Second + Additive is the right way to go, whereas I *might* have been subtracting the additive (double subtraction).
If this is accurate, I'm off by about 25 KPA across the entire curve... Correcting for that in the log makes it look like this:
A whopping 6 PSI sees 3.8v @ 8k RPM...I don't think I'll need more than a stock MAP sensor to max the turbo after all.
