DIY Port injection set up
H
Hey man, I was wondering why is the left side of the PI rail blocked but the diagram/drawing you attached to one of the posts above is that a fitting is connected there?
Originally I didnt have a return. Later iteration of the system included a return and a fuel pressure regulator
Sent from my SM-G950U using Tapatalk
Sorry about the late post though i just completeld my return system using a walbro 460 lt per hr pump and it’s working fine. i just want to thanks everyone for their input which help me create mine.
@Mark Ringor What are you using to hold the pump in?
Also is it a unmodified basket since you don't have the ring that Mason made to sit inside the basket without the retainer?
the actual walbro upper body is almost the same size as the oem pump. all i did is modify the fuel filter to suite the walbro pump. the filter doesn’t work now though, so i had to fit an external in line fuel filter.
My FP starts at 48 psi and it shoots up to 83 psi as i boost up. what i found was the car rans smoother and the part throttle KR dropped dramatically. i don’t know if it’s related to a colder fuel due to the return
Stock wiring for this setup?
Thread viewers
