I used a pre pump filter sock similar but larger than what is used on an oem pumpDo you think fuel filter's may be required as iv been reading about pre and post ones ?
hey mate, can you give me the link for the 1000cc injectors please and the list as its the last day of the sales ?
Not to revive an oldish thread I’m trying to go this route as well. I currently ran a 6th port setup but ran out of fuel so I’m looking to do the st mani with the Damond pi. Now is it possible to run returnless on this setup or is that asking for trouble? I have a aem 50-1220 pump that’s good for 320lph at 43psi.
Any pics of how you did this? My goal is right around 580-600. Getting a jmf v2 and running whatever you guys think would be best. I’m looking at doing return but don’t see what runs to the hpfp, port rail, and then where the return actually goes. I guess I’m dumb here lol trying to figure it out. Thanks @alexwlwsn @MaisonviYeah I think returnless is possible, but if you are already maxing out a 6th port system, I would guess you are at the limit. Luckily, its really not too bad to make the system returned. the hardest part is fittings in the stock basket, which really you could just use the stock feed line still as it is, and just run your own return. (I chose to run the stock line as the return but that meant no using a drop in pump)
You might have to calculate the stock feed line size to see if its big enough for your goals, should be easy enough to do.
I have pics, in this thread, or maybe its my build thread. When I get to a computer I will link themAny pics of how you did this? My goal is right around 580-600. Getting a jmf v2 and running whatever you guys think would be best. I’m looking at doing return but don’t see what runs to the hpfp, port rail, and then where the return actually goes. I guess I’m dumb here lol trying to figure it out. Thanks @alexwlwsn @Maisonvi
Sounds good @Maisonvi ill look on the threads and see if I can find itI have pics, in this thread, or maybe its my build thread. When I get to a computer I will link them
Sent from my SM-G950U using Tapatalk
@Maisonvi hey bro, are you interested in selling/making one of your walbro 450 mounts? I'm pretty much copying your setup, many guys said to run surge tank but not nuff funds for that, I've seen justin@freektune did his walbro, like just drop it and zip tied? Will that work? And just drilling top hat for return? Sounds simple but feels like I'm missing something lol
So did you go with the first way or second way? And I’m such a doofusThis was the plan I have in place now. I found it from an older (apparently) SP36 document. Made sense to me at the time as a good way to do it.
This is the new plan: (Sorry for the shitty MS Paint drawing:
Seems like the second way is how most people run it. I was under the impression the first way would work as well, especially with me having small injectors for the PI system.
I'm out right now. I will do a write up here for you and everyone else. I've been saying I will forever@Maisonvi if you can provide all the parts used to run the return and what fittings and what you did to your fuel basket for the return and everything. I’m being stupid and don’t know shit. This is just something I only want to do once
[doublepost=1517693926][/doublepost]
Ok, I wrote up all the parts I used and how I laid everything out. The only thing I dont have is the compression fittings as I bought them locally, but they are just 6an male to 5/16 compression fittings. (if you cant find them let me know and I will look up a part number)
Ignore the lengths and what not of the lines, I just used what space I had available on the page. I think the hose going from the basket to the HPFP was like 10 ft, the rail to the FPR was like 3, and then another 2 to the fire wall. Depends on how you route it, but I think I used about 15 ft total. Kinda a guess at this point tough.
All the fittings and hose were ordered from here (and thus the part numbers) it was the cheapest I could find at the time for the fittings I wanted. https://www.verociousmotorsports.com/
Other parts I used:
AEM Fuel Pressure Regulator (Part Number: 25-302BK):
http://www.aemelectronics.com/produ.../universal-adjustable-fuel-pressure-regulator
Walbro 450 pump (Part Number: F90000267)
http://walbrofuelpumps.com/walbro-f90000267-fuel-pump-e85
Walbro install kit, to connect to the stock system as my just had loose wire leads, and gave me a filter sock. I dont think I ended up using the connector and just cut and soldered the one off the stock pump on to mine. I also used fuel rated shrink wrap FYI.
www.amazon.com/gp/product/B00FMUZMOW/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
For the return drain hose, this is what I used so it would dump back into the bucket.
www.amazon.com/gp/product/B001R5XX56/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Injectors: Injector Dynamics ID1000, I dont think they make these anymore, they are now ID1050s But use what makes sense for your goals
As far as parts I made, the holder for the Walbro is mine, and then I had to modify the bulk head fitting to make it work as a hose fitting. There might be a fitting out there that just does this, I just had this one and made it work. I did have to trim out the inside of the basket to get a flat spot to mount the bulkhead fitting. I did it with a razor blade and a dremel tool. Easy work. Ive attached pictures of what I did in case I haven't posted them before.
Stock Bulkhead Fitting
Modified
Mounted from above:
What I had to do underneath:
Final installed pic:
let me know if you have questuions
In your case you would use the stock feed line and connect to the firewall just like I have but go to the HPFP instead of the regulator. And then from the regulator you would go back to the tank with a DIY return line. I can draw up a diagram tomorrow when I'm back at work (where I saved this file)So I have a fuel pump in tank that fit in stock location do I have to modify all this to my basket to make this work? What’s confusing is using the stock feed line to return fuel. I’m being dumb af but I guess I’m just a little confused about that. Thank you for all your help and insight and part numbers you’ve been a tonnn of help @Maisonvi
