JohnnyTightlips
Motorhead
Here I am going to list useful wiring stuff people have found over the years. Please post stuff you also know about so that we can get a decent list going.
Throttle Body
Ford/Mazda 6 Way with keyway for DBW Throttle Body Connector Plug Kit Part # CONN-76080
Ford/Mazda 6 Way with keyway for DBW Throttle Body Connector Plug Pigtail Part # CONN-86080
EBCS
2 - Way Receptacle Connector Pigtail Part # CONN-85730
Coil Plugs
3 Way Plug connector pigtail for Nissan and Mazda coils Part # CONN-85775
NICECNC Ignition Coil Pack Repair Kit Connector for Nissan 350Z 03-09,370Z 09-16,Altima 02-16,Frontier 05-16,Maxima 90-16,Murano 03-16,NV1500/2500/3500 12-16,Pathfinde 01-16,Quest 04-16,Xterra 05-15
02 Sensor
4 Way Connector Extension for Japanese applications, Gray
4 Way NC Miata MX-5 Front Oxygen Sensor Extension
Maf Sensor
5 Way Plug Kit for Subaru & Toyota MAF
Ford Mass Air Flow MAF 24" Extension Harness Sensor Connector Harness 6-wire pin
Bosch Map Sensor
4-way sealed Plug Bosch BSK Connector Kit for Bosch MAP Sensor
VVT Variable Valve Timing and OCV Oil Control Valve
2 Way Solenoid Connector Kit for Mazda VCT VVT and Air Solenoids
Alternator
Sumitomo TS 3 Way Alternator Plug Pigtail, (Toyota # 90980-11349)
Parts to Build a Coil Wire Tuck
https://www.corsa-technic.com/
Throttle Body
EBCS
Coil Plugs
02 Sensor
Maf Sensor
Bosch Map Sensor
Alternator
