I might have had the traction control still on, the weight was just some stuff in my trunk plus a bit in my backseat but not a bunch, and everytime I go wot I see a grey/black cloud of smoke as if it’s running rich so I agree it should be leaned out some. And @Gizmo your VD graph shows you were in 4th gear? Mine was in 3rd as well so maybe if I do a 3rd gear and a 4th gear pull I can compare them on the VD.Get a fresh log and check again. Make sure the road isn't uphill or downhill and you don't have a bunch of extra weight. You said you had a bunch of extra weight in the car, how much? You can account for that in VDyno, but I wouldn't do pulls with a bunch of extra weight on the car if I could help it.
Do you have traction control off? Are you actually targeting 11 AFR at WOT? It's jumping between 11-10.44 in the logs, which is a bit rich. I'm targeting 11.8, but I think the norm is like 11.4.
[doublepost=1529349104][/doublepost]Also @VashEXE Jason said he was targeting 11:1 but being rich can cause some power loss compared to running more lean correct?
