Purchased @VTMongoose 's
07 Mazdaspeed 3 Aug 22nd. Had the car plated in 2 days. What a phenomenal car this is. Very capble and in amazing condition to boot. Seeing as I've been passed the torch I plan to continue this build's general course. This will be a road course build and has been setup beautifully already for that purpose.
So far:
Shook the car down and I'm very impressed. (literally battery terminal clean up and PTFE spring guide from ground control) good to go neither was really needed but im anal......
Ordered an oil pressure, an oil temp gauge, and sandwich plate from corksport. Block8head dual pod. Heat Mat, Heat Tape, and stainless steel sheet for a custom heat shield.
Began the development of a custom boost activated intetcooler/rad mister from misc aftermarket and OEM parts.
1 gallon system ~10 mins of mist from 3 nozzles(2 on rad 1 on intercooler maybe) boost activated or momentary push button activated. Tank should be mounted in hatch.
Micro Plans:
Get gauges installed, add custom heat shield to firewall above mani shielding the cowl. Shield brake booster and charge coupler coming off turbo. Add additional shielding behind factory shield.
Drive the crap out of it.
Macro Plans:
Not so sure, small-mid turbo to widen the power band a bit on stock fueling. ST intake if I can work out TMIC mounting.
Even longer term:
More tire, more spring, damper revalve maybe some trick magnetic shocks Ive heard about recently.
Who knows how it'll actually end time will tell.
Updates coming soon as I start to work on the car maybe some video too who knows.
![1025211734c[1].jpg 1025211734c[1].jpg](https://www.mazdaspeeds.org/data/attachments/20/20649-ded938297eba99bad1eb138848061e0c.jpg?hash=3tk4KX66mb)
