Yeah that's true didn't think about that so good point.bi used blue but we will see idk.IIRC Loctite Red is specifically formulated to give up the grab with heat...Using it on an exhaust manifold will probably get you nowhere.
I might end up having to just weld the adapter on but welding stainless to cast isn't ideal at all obviously lolI think your best bet will be a lockwasher; looks like there might be just enough room for one.
Got everything tested and checked. Didn't find any leaks up to 25psi anymore and gapped my plugs to 0.025. With all that said I still am having very lean idle issues.
Wondering if my maf or o2 could work during higher rpm/voltage but not during idle. Feels decent under boost and normal driving but stutters sometimes at a cruise when giving it very slight gas to keep it the same speed.
If anyone has ideas let me know!!
Only thing I can imagine is if the heat from my exhaust leaking massively could've screwed up the primary o2 wiring somewhere.
I'm way past stock mani bro lolcould it be something with EGR not closing properly making u go lean? don't know if your EGR is deleted or not. I think i saw Enki say it but an exhaust leak could also cause a lean at idle, check for cracks in the accordion on the EM
