Code Monkey
I have seen high coolant temps....
How high are those mystical temps.
I usually pull off the track when I hit 240-245How high are those mystical temps.
Those temps are insane. Good thing you have a built motor. I haven't tracked my car with a larger turbo yet, but the highest temps I saw on my Pu with all of the shrouds/undertray...etc in place when we were at Autobahn was like 207.
I would definitely consider putting all of that shit back on, literally every stock piece you have, and see if it helps. Definitely possible the airflow through your engine bay is fucked because you're missing some airflow/vacuum effect the stock pieces like the undertray somehow promote.
Also, if you've removed the under hood ducting for the TMIC, I'd even throw that back on and see if it makes a difference. After all, it's going to direct airflow on top of the engine and push heat from the manifold/turbo area underneath the car while you're moving.
What weight oil are you running? Heavier oil will run cooler. Though you have to be careful to use a weight appropriate for the typical use so you probably cant go heavier than 50 or 60
There is definitely something wrong with the cooling system. I usually see around 190-200 on my racepig. Run the undertray and duct the radiator as much as possible. For coolant, consider running 1 quart of 50/50 coolant, 1/2 bottle of Redline water wetter, and for the remainder use distilled water. I hope you did not leave a rag or piece of tape in a coolant hose or pipe so it is partially blocking coolant flow, would not hurt to check.
How much boost are you pushing? Consider detuning a bit for road racing. Evos have EM in the front so their hood vents work there nicely. For us, if you put hood vents over the EM, at speed you will be most likely pushing air into the engine bay rather than evacuating it.
For some reason I thought you were still on a TMIC. I am not sure if there is enough space to angle the FMIC a bit or even lay flat and have a separate ducting for the IC and the radiator. In any case, with a FMIC make sure to use something like JBR's airdam so that all the air goes through the radiator and not into the engine bay.
The base of the windshield has a higher pressure than the engine bay when the car is moving. The rear weatherstrip should only be removed on drag cars where you sit in the staging lane.
You should put the understray back on.
Turbo blanket, coating on the manifold and some heat shields around the turbo will help too.
Pretty sure you are fmic in which case you should make sure that any radiator shrouding that was removed for the installation of the piping is modified so that in can be replaced.
The idea being that the stock configuration is pretty well designed and the removal of a bunch of small parts from the stock setup can add up to a big difference in temps.
And details on temp fvariations? I tore mine off and gave it away. Because all it did was get in the way.It's not just there to get in your way.![]()
I do have the Raider's JRB Damn (shocking) to prevent crap from falling into the pit of doom. Guess the diverter panel was an added bonus.
Pussies^ IIRC they are restricted to run like 14 psi boost max.
So should factory mustangs get a reduction too then?
Pussies
[doublepost=1462585029][/doublepost]Though it was probably to keep them from torque steering into the other cars.
